It is currently Tue Jul 29, 2025 7:28 pm
 Post subject: neck mounting question
PostPosted: Fri May 22, 2015 7:03 pm
First name: Doug
Last Name: Serson
City: High Falls
Zip/Postal Code: 12440
I am engaged in my first guitar build, a telecaster and I have a few questions for anyone who might help.
1. Size of pilot holes for neck mount. I read somewhere to use the same bit size for both the body and the neck. I did this and ran into the trouble I expected. I can't easily draw the neck down to the body. I assume I should make the holes in the body larger. Correct?
2. Any suggestions for wiring a 4 way switch to a p90 in the neck and a single coil in the bridge. I found plenty of diagrams for 4 switching with 2 single coils. Is there any difference in the schematic if I am including a P90?
Thanks in advance for any help!
PostPosted: Fri May 22, 2015 8:50 pm
First name: D
Last Name: S
1. Yes, correct. The holes in the body must be just large enough to not grab the screw threads.
2. Not sure about a P90, but I thought they were single coils.
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri May 22, 2015 9:10 pm
Yes, enlarge the holes to be an easy fit for the screws. this will also allow for adjusting the neck alignment.
The P90 should just be a single coil so the 4 way arrangement is the same, but it may have the ground and second coil end wire soldered to the braided shield at the pickup instead of 2 conductors. You would then have to rewire the pickup to have 2 conductors plus earth if you want to use 4 way switching.
